I haven't found any posts specifically talking about using minidsp to eq multpile subs. I'm not interested in using REW to auto import filters. I'd rather hear people's thought on the best way to do things manually.
There are so many ways to do it:
1. Measure each sub and apply filters to tame peaks to each sub individually and then run Audyssey.
2. Measure both subs together and apply the same filter to both subs and then run Audyssey.
3. Run Audyssey first, then measure each sub and apply filters individually.
4. Run Audyssey first, then measure both subs and apply the same filters to each.
What do you do? So far I've had the best luck with 4. Although I've had to add some boosts.
