Have you considered moving it? I had the same problem in my project (2 poles actually). I moved them both and reinforced the beam. Had an engineer draw it up, the municipality approve it, then did it myself (apart from the welding). Its actually not that hard. You just need to make sure you get the drawings done first by a good structural engineer.
Here is a link to the entire process I used on another forum (Holmes on Homes) if that's helpful. I will eventually post my theater project here, but haven't gotten around to it yet.
http://wurzerenterprises.com/phpBB2/...612&highlight=
Originally Posted by Schwingding There's this DAMNED pole sitting smack dab in the middle of the basement. It cannot be removed. Instead, I pretty much have to choose one side or the other of the 19'x25' room |
