Status
Not open for further replies.
1 - 2 of 2 Posts
I have a Kenwood KC-X1 digital av control amplifier/tuner and the matching KM-X1 6 channel power amplifier.
Would I be better of getting a new all in one unit that has the power amplifier and receiver in one or get a new digital av control amplifier/tuner.
I would like to have support for all of the new formats.
Any product suggestions would also be helpful
I currently have the following setup.
KC-X1
KM-X1
Sony 5 disc DVD
Sony HiFi VHS
TiVo
Digital Cable
PS2
36" Toshiba
Separates usually give improved performance, mainly because a separate amp will almost always be better than the all-in-one receiver's amps. However, if you set all your speakers to small and use a sub you may notice much difference if you use one of the better powered receivers. So if your budget and rack space are limited you can do just fine with a good receiver. I recommend one of H/K's bigger receivers - AVR520 or bigger because they have better amps than most other brands. They will also make a good pre/pro/tuner if you decide to add a separate amp later.
Dsmith
1 - 2 of 2 Posts
Status
