I am getting several error codes on a Hughes/JVC 310E. I wired the projector to operate from my 220 VAC single phase dryer outlet and the unit powers up using the remote control. When I press the menu function it does not display the menu, the projector displays the error code 0. Acording to the manual that indcates that all functions from the Systen Control Board (SCB) are operating properly. If I keep pressing the remote control Escape (ESC) at times it will cycle through the inputs and display the Xenon lamp output for about a half second. Once in while it will display error code #. It appears to be in default input 1 (RGBHV).
Also, the projector will not turn off uning the remote control. I have to unplug it to turn it off. Is the projector looking for a password? How can I get it to accept a video signal? Any help appreciated.
Thank you forum Menbers.
Al
Al
