Hi! I just started using Escient's Pipeline software with my Tunebase 200, and have encountered a problem. When I edit information or add covers, it will only update my Tunebase if I sync after each change. For instance, if I add a cover for an album and sync, it works fine. But if I add 5 covers and sync, nothing.
any ideas?
thank you!!
any ideas?
thank you!!
