Anyone know the specs on the estar 6000 usb charger? I can't find the original cable and need to buy a replacement. I found a similar USB cable, but the plug is too big to fit into the glasses. Hopefully someone knows the volts and amps as well as the plug radius?
A google search for the estar charger turned up nothing but maybe if I have the specs, I can find the same style charger from a different company.
