Status
Not open for further replies.
1 - 9 of 9 Posts
Here is my current plan right now. I'm planning to buy 2 Paradigm Mini-Monitors listed here: http://www.paradigm.com/Website/Site...nitorSpecs.htm
For the Subwoofer, I'm thinking of the PS-1000: http://www.paradigm.com/Website/Site...ries_Specs.htm
For the Receiver, I'm thinking of the Panasonic XR-55. This will all be connected to my computer as audio speakers. My room size is 216 inches x 152 inches. Is this setup overkill by any means for a room of my size? I'm planning to use this for everything that I'll be doing on the computer (i.e. listening to music, watch movies, trailers, games).
Late next year, I'll get 3 more speakers from the Paradigm Monitor series to complete the package so I'll get 5.1 surround sound. Is this a good move by me? Thank you.
It's hard to know what to say. Starting with 2.1 certainly makes sense. I'd rather see you get good mains rather than lousy 5.1. The specific choice of components tends to be personal taste. I like Paradigm speakers, though I'm higher in their product line. I don't know the Panasonic.
I don't think it's overkill. If you like good music it's perfectly sensible to use a high quality system with a computer. In my setup my speakers are just about 3 feet from me. If you're in that situation, make sure you listen to the speakers at the same distance. Speakers often sound different up close.
Discussion Starter · #6 ·
My room is 216x152 inches. Is that too small for such speakers? I'm considering BW, but I'm not quite sure if they're available in Vancouver, Canada. Another thing I don't like about the Paradigm Monitor series is that it doesn't come in black :(
Last pair of Paradigm Monitors as well as the Studio series I bought were black,if your dealer won't order them in black for you find another dealer.
Another vote for the Paradigms! I started with Mini-mons and moved up to Studios now, but enjoyed the Minis when I had them. :D
1 - 9 of 9 Posts
Status
