I'm still figuring out what to do with my Barco 808 and am leaning back toward ceiling mounting it even though I have a drop ceiling that's 7.5 feet off the ground....I figure if I flush mount the projector against the drop ceiling, the top of a 16x9 image that's 80 inches wide will be more or less 16 inches below the ceiling height, which is okay...if I want to go to 4x3 at 80" wide I think the top of the image will be right against the ceiling, which is not great but acceptable for the few times I might do that (superbowl, etc.).
Sadly, I found out there is a heating/ac duct right where I need to hang the PJ, running perpendcular to the joists, that would be a huge problem to build a mount around or reroute (rerouting is tough due to sprinkler pipes).
But since the duct only leads to 1 or 2 vents in a basement that we usually keep closed, I figured why not just punch some unistrut through the duct so I can get right to the joists I need.
Anyone ever do this? And, is this a really stupid idea? On the one hand I think, "Hm, as long as the seal around the unistrut holes is tight, this shouldn't be too bad." On the other hand, this could just be a "Problem? Smash problem!" response driven by frustration.
c
c
