Status
Not open for further replies.
1 - 4 of 4 Posts
Hello
Currently HTPC - Arcam AV8 - DIVA P85 3ch + P85 2ch - M&K THX Select speakers.
Do larger rated amps (looking at x 3 Arcam P1 mono's for front) only make a difference for larger rooms, mine is only 14 x 12?
Would i notice much of an improvement and what would it be?
Andy
We have similarly sized rooms. Is yours a dedicated room? Unless it is, I don't think seven channels are necessary.
When it comes to the AV8, get the best amp you can afford. You'll likely get greater clarity and focus as rewards. The level of improvement is personal and arbitrary, though.
Discussion Starter · #4 ·
Yes its a dedicated room...
"improvement is personal and arbitrary", yeah, i'm never sure if i've convinced myself of improvements because of how much i have spent!!
1 - 4 of 4 Posts
Status
