I'm moving into a new house (existing construction) in a couple of weeks. We have a Frontpoint alarm system (wireless/cellular) in our current home and like it but aren't tied to it.
My only requirements for my new house are:
- wireless / cellular
- ability to control the system through an app from anywhere
- ability to connect it to a Control 4 system in the future when I get one
I need about 23 door/window sensors, 3 smoke alarms, 3 glass break sensors, 1 control panel, and 1 touch panel (for arm/disarm only).
I've heard from my C4 dealer that the Ademco Vista20p + ADT would be a good choice. However, ADT doesn't install that brand if you go with them.
An ADT reseller I talked to said that if I had an existing system in my house, they would be able to program/activate it with ADT monitoring for me (and he said the Vista20p would be fine).
So I would love your advice, as I see a couple of options:
1) Keep my Frontpoint system (and add on to it), but ONLY if I can hook it into C4 some day (It's a GE system with a GE Simon XT control panel)
2) Have ADT do a fresh install with their ADT Pulse system, but ONLY if I can hook it into C4 some day (I have no idea what brand they use)
3) Have the ADT reseller install my system with DSC components, but ONLY if I can hook it into C4 some day
4) Buy the Ademco Vista20p on my own ( http://www.homesecuritystore.com/p-1169-v20p-wls-honeywell-vista20p-security-kit.aspx ) and add on to it myself to get the system I need. Then, have the reseller come in and take me "existing" system and connect it to ADT.
Does anyone have experience with this? I would prefer option 1 if it works with Control4. Otherwise, options 2 and 3 seem the most expensive so I'd prefer 4 if it's easy enough for a first-timer.
Scott
Scott
