1 - 6 of 6 Posts
I have the Sony FDRAX100 camcorder and was shocked to see that a replacement NPFV50 battery would cost over £70.Is there a good alternative that will have similar performance?Is there something special (apart from the price)with a Sony battery?
This trick is becoming more common. Panasonic have practiced this for some time. To quote numbers for clarity, the 180/360 batteries, suitable for my three year old HC-V700 camcorder, were available from third parties for around £25 for the larger 360. The 190/380 batteries for my more recent camera the HC-V750 are not produced by third parties yet but Panasonic replacements can be got for £59 (190) and £81 (380) from Amazon.
Seems Sony are on the same game.
Discussion Starter · #3 ·
Are these 3rd party batteries any good?
In my case Yes. I bought from Digitalmediastore where the VW-VBK 360 (NOT 380) is still 25.99. Unfortunately they only work for the 700 and NOT the 720 - 750 etc. The battery is as good as its description and has a double life compared to the Panasonic 180. (supplied with the camera.)
The Panasonic cameras charge at 5V and use a charging cord with a USB plug on one end. This means that you can charge or run the camera from a USB charger OR one of these phone chargers which use a battery (again see Amazon), a number of 750 users are running their cameras from these charger packs. Does this apply to the Sony?
Yes, they're not cheap.
The cost of a replacement NP-FV70 (the one that comes with the camera) is £69, and a NP-FV100 is £99 from the UK Sony store.
Amazon are a pound or two cheaper
I tend to use a NP-FV100 because of the extended shooting life.
No alternative batteries are quite as good as Sony ones in terms of performance, but some are quite acceptable.
Alternatives to the NP-FV70 that I've tried are from:
  • Jupio (£25), and
  • Duracell (£33)
Alternatives to the NP-FV100 that I've tried are from:
  • Wasabi (comes as a 2-battery pack with charger)
You may find them adequate for your needs, although they don't have the same capacity as the Sony ones.
Yes, they're hand-crafted by elves and delivered on the backs of golden unicorns. (Or at least that's the only explanation I can come up with for Sony pricing.)
1 - 6 of 6 Posts
