Look at it and figure it out?
Originally Posted by ZilchLab /forum/post/16860279
Series-ported triple-chamber bandpass....
Originally Posted by vasyachkin /forum/post/16861707
i did. but i want your opinions.
Originally Posted by mgboy /forum/post/16861844
Which is it? You didn't, or you don't?
Get whatever was stuck up your bum from childbirth out, and move on in life.
Originally Posted by mynym /forum/post/16862302
Bi-Chamber
Originally Posted by brandonnash /forum/post/16862107
Pseudo bandpass that instead of deadening either the front or back wave it ports both thru to send it thru the outside port. Why they would do this I don't know because it seems it would give extremely limited bandwidth. The shorter interior port looks larger so it should get a different interior tune from the smaller diameter port. I imagine the exterior port is there to lessen the horrible amount of chuffing this produces.
Originally Posted by vasyachkin /forum/post/16862374
slow down. i thought we agreed it has 3 chambers ...
not to mention that the rear chamber is not ported to the outside.
Originally Posted by Ricci /forum/post/16862541
I wouldn't mind messing around with a design like this. It may be solid if done right (probably tricky) Just imagine if you used real drivers instead? If they can get any real bass out of 5.25" stamped frame $4 speakers it might be interesting with some 8" TB's or something. Maybe use PR's instead of ports.
