Todd,
I would suspect your set's HD mode might be a large part of the problem. You said you had to adjust the other modes with Avia so I would also suspect the HD mode's geometry and overscan might also be off. I have not heard that the SA2000HD box has major geometry issues. I have some HD geometry issues on my set but I am 99% sure it is the set and not the box. I have a new box coming today and if it is significantly different than #1 was I will holler (first box died; corrupt firmware; local problem).
To further narrow down the problem; you need to have the HD mode checked. Can you call your seller and have it checked? Can you try another box or stb to see if that fixes the problem?
As a last resort, if you can borrow a STB like the RCA DTC-100 there is a way (reportedly) to feed the Avia disk output into the STB (some have used a vcr in-between). The RCA has an output option of 540p that works like upverting to 1080i. This apparently is not bad for checking basic geometry of your set's HD mode. (ps; using the SA2000HD for this did not work for me).
Good luck
Bruce in SC
Mits WS55807
TW SA2000HD
Good luck
Bruce in SC
Mits WS55807
TW SA2000HD
