Extended Warranty - Help Using
648 Views 1 Reply 2 Participants Last post by  eliteconcept
Hi
I have a Sharp 46d62u...
When I purchased the TV, I also got the extended warranty...
Well, the banding on my TV has finally driven me over the edge, and I was planning on calling in the extended warranty and having it replaced.
My question is, what do I go about saying (or not saying) when I call them up?
I noticed there no longer are any 46d62u's will they replace mine with a d64u? What other things should I keep in mind when I call them up?
Thanks for you help!
1 - 2 of 2 Posts
good luck thats all i have to say.
sharps service gets a c- from me.
my tv has banding, and has from the day i bought it. Also in the first month of ownership didn't turn on properly 2 times. I called sharp told them of both problems, and they send a tech out. he comes out says he can't do anything that day. comes back a couple weeks later with a new board for the tv. takes some pictures of the banding after doing a firmware upgrade doesn't replace the board and leaves. banding is still there today.
If you get them to give you a replacement tell me how you did it cause I need to do the same thing.
my understanding is that they won't GIVE you a 64u replacement you can "upgrade" to it for like $150 or so.
1 - 2 of 2 Posts
