1 - 3 of 3 Posts
Yes it should work. One thing to check though is the size of the IR mini blasters that come with the Harmony Smart Phone Hub -- in the past Logitech has used 2.5mm jacks instead of the more common 3.5mm jacks. May need to get an adapter from 2.5 to 3.5mm from monoprice or radio shack if that is the case.
1 - 3 of 3 Posts
