Status
Not open for further replies.
1 - 15 of 15 Posts
Hi,
I'm needing to have cable runs for my xbox controllers in lengths ranging from 20 to 50 feet. I'm looking to avoid any signal loss.
It's for a huge home theater setup, and I cannot move the xboxs. I also cannot go wireless, because I need to use the original xbox controllers, and because I'll be using up to 16 controllers at once sometimes.
I've considered buying a bunch of xbox extension cables, but Boid says on his faq that 2 daisy-chained are feasible, but 3 start to create problems.
I've considered the possibility of purchasing whatever kind of cable the controller uses in really long lengths, slicing my controller cables in half, and soldering the two together.
But what kind of cable does the xbox controller use? How long could I make my runs before I experienced signal loss? Would I need to use some type of signal amplifier with them? How would I do this?
Any suggestions would be greatly appreciated.
Bradley
i think you could use a cat 5 cable, just buy a big spool,
or you could convert to usb and use repeaters and hubs, then convert back to the xbox controller.
your project sounds interesting, please keep us updated!
The controllers are hooked up via a USB controller, so a USB/xbox run are equal, what does that mean...who knows "The Screen Savers" tried to find out the limit USB would stop/error transmitting data and they ran out of extensions.
Instead of splicing the controller cables themselves, buy some cheap extension cables and hack those apart. Never modify the original piece when you can avoid it. :)
- Chris
As mentioned above, the xbox controllers are really usb devices. The general rule of thumb for USB is not to exceed 15 feet in any segment without a hub. That is usually a little on the conservative side and is intended more towards data intensive devices like scanners, cameras and storage devices. A controller sending comparatively little data can probably get by with a longer extension, but I'd doubt you could go 50' in a run without problems.
If only there was an xbox to usb and usb to xbox adapter. Does anyone have info on the xbox controller pinout? I remember hearing something about them using non standard power on one of the lines.
Kris
Why don't you just experiment and see how it works with a bunch of extensions?
Just out of curiosity, ever thought about getting a wireless controller? I have the MadCatz controller. It's about $60 from Fry's. Works great.
He said he couldn't go wireless because he needed to use the original Xbox controllers. Having 16 people at once, it sounds like he's running some tournaments or some serious multiplayer competition of some sort, so maybe he wants the plain jane Xbox controllers to make sure the playing field is even as far as controllers go (??).
If there's one site that might have the answer, it's gamesx . I couldn't find the Xbox controller pinouts in particular(the video connection pinouts are there), but I'm sure someone there knows what they are. Give 'em a try, I know they've helped me out more than I can remember.
-Phil
My dog ate one of my cables a while back and I re-soldered it together. The wire was standard 20-22 AWG nothing special in the twist or layering. I would reccomend testing it with 50' of cat5e cable spliced to an XBOX extension cable and see how it works.
You can use more than 2 extensions [ I have used 4 at once and it worked fine with an original S-controller - this was over 30' but not 50' ] . The only feature you might lose with longer runs is the 'rumble' [ this is what happens with the PS2 ] .
-- Jason Berg
Jason, whassup! How many PS2 extentions did you use before you lost the rumble feature???
Hey ,
-- I think it was 4 extensions with the PS2 and no rumble but 3 would still get it [ each extension was 6' ] .
--- Jason
Awesome! I only need 2 so I'll be cool!!! Thanks for the experiment!
1 - 15 of 15 Posts
Status
