Status
Not open for further replies.
1 - 2 of 2 Posts
Hey all,
In my pc I have a R9700pro that uses a 15pin to 9pin cable that goes to a extron 118 plus. The problem that I am having is when I use this setup in display settings the monitor is grayed off. When I use my breakout cable 15pin to 5 bnc's, everything is fine in the display settings...
Is there away to use the extron and have the r9700 card think that theres a display hooked up.... The only thing that I could think of is that with the extron there is no load on the cable, so I doesn't think its hooked up.
Any ideas ?
Brian
1 - 2 of 2 Posts
Status
