Status
Not open for further replies.
1 - 5 of 5 Posts
Interested in the F38310 RCA HDTV and have a question about the RRS38G stand: How much equipment can it hold?
I have a large EAD PowerMaster 1000 amplifier, a B&K Reference 30 Processor, and a Panasonic RP91 DVD player. Will it all fit into the RRS38G stand? Is it easy/possible to access the backplane of my electronics with this stand?
Thanks in advance for your advice.
Nick
Nick,
One of the problems with this set (The only problem I've had), is that it's almost 45 inches wide. Most TV stands are not that wide.
I did not get the RCA stand when I purchased my set last April.
I just order one that is 45 inches wide and 32 inches high, equaling 3 shelves.
If you have any location in your area that sells ASPEN Furniture, it's module A1045.
Good luck
Don
Discussion Starter · #4 ·
Thanks, Don for your insightful reply... does anyone else have a stand that has worked well with the F38310 and 3 or 4 additional pieces of electronics?
TIA,
Nick
I have the F38310 on top of a Bello AVSC-2103. It fits perfectly and has 3 shelves that can fit up to 6 standard sized components. Its not cheap (about $500) but looks very nice if you like contemporary furniture (its made in Italy). I also bought the matching autio tower.
Gerry
1 - 5 of 5 Posts
Status
