Status
Not open for further replies.
1 - 6 of 6 Posts
how do I access the service menu? Thanks
Originally posted by Benji
Some things are just better left alone.
I some cases, perhaps.
But with the geometry problems out of the box and the lack of technical expertise (or unwillingness) from 'authorized technicians' to adjust the set, it can be better to take matters into your own hands.
It worked for many of us.
All of the posts recommend cautions and it's up the individual to decide whether they can perform the tweaks themselves.
I was a little nervous about the service menu, but I'm glad I tweaked mine. Just make sure you understand all the directions before you start, and WRITE EVERYTHING DOWN BEFORE YOU CHANGE IT!
Good luck.
1 - 6 of 6 Posts
Status
