Thanks to all of you for all the help and advice you post on a daily basis. I have truly learned a great deal from all your wisdom. In an attempt to pass back some information, here is a way to get one of the nice features of the Lutron Spacer to work with a programmable remote like the Pronto.
For those of you who like myself have been unable to figure out the "fade to off" feature and are not pleased with the rigged dim-pause-dim-pause solution, here is the IR code to make this work:
0000 0067 0000 0007 0333 0113 005b 0113 005b 005c 016c 005c 005b 0113 005b 00b7 005b 01f5
You can now press and hold a button on your Pronto programed with this code, or build a macro that uses a series of these sequentially to automatically increase the delay time before the fade event (I found that it took about 8 of these to activate the delay and required me putting .1 second delays in between each alias to make this work).
Anyway, hope this helps those like myself who have been trying in vain to get this to work!
