The remote on my 1015TX no longer works and a local repair shop says that the sensor on the circuit board has failed. They also tell me that the sensor is not supplied by Pioneer as a seperate replacement part and a complete new circuit board will be needed at a cost of around $250. Has anyone else had this problem or have any suggestions what to do? The unit works fine when controlled manually but because of the physical location of our AV setup, the use of a remote is essential. Any help gratefully appreciated.
