Status
Not open for further replies.
1 - 1 of 1 Posts
· Registered
I love my Ampro 4000 but I realy wan´t it more quiet (and better airflow)
So I have loket at some fans to change my old fans in my proj. because the projector is about 10 years old( 1 800 h.) the fans which is in it now will not be as quiet or have the airflow of some new fans.
I have 3 fans in this projector.
Starting with the small 60*60 *25 fan which is located in the smps
the origanall one is a
NMB DC 2410ML 04w B30
http://www.nmbtech.com/products/fans/dc2410ml.html
31 db 19cfm and pressur of 0.16 inch-h20 ballbering
the replacement fans (all 60*60*25)
Power Cooler PS6025M
25dB 20.89CFM and pressur of 0.18 inch-h20 sleevbering
http://www.powercooler.com.tw/DCFAN/6025.htm
(this is my primary replacement choose right now)
Thermaltake F126025BH (TT-6025A-2B)
28db 21 cfm and pressur of 5.33 mm-h20 2 Ball Bearing
http://www.thermaltake.com/products/dcfan/6025.htm
Now on to the two bigger ones in the chassie
this two is of 80*80* 25 typ
and it´s no sticker on them so can´t know exactly what brand and model
but by looking at other projector I have come to the conclusion that it´s a NMB fan of model DC 3110KL (some Marquee model use them and when it´s a nmb fan in the smps that not totaly unexpected that they use nmb fans at the bigger fans)
http://www.nmbtech.com/products/fans/dc3110kl.html
but don´t know what type 04w or 05w and if it´s a b20, b30 or b40
here is the spec for them all
ballbering
b20 25 db 28cfm pressur 0.08 inch-h20
b30 28 db 32cfm pressur 0.10 inch-h20
b40 31 db 35cfm pressur 0.13 inch-h20
b50 34 db 39cfm pressur 0.15 inch-h20
Thermaltake Smartfan A1214
temp control fan
27-39 db 46 - 53cfm 2 ball bering
on this I can take away the temp resistor and replace it with a regular resistor (or a trim pot)and have it going 27db 46 cfm all the time
http://www.thermaltake.com/products/dcfan/a1214.htm
Enermax UC-8FAB
speed regulated fan
14-32.6 db max 39.4CFM ball bering
http://www.enermax.com.tw/products/peripherals-main.htm
Noiseblocker UltraSilentFan S3
1 - 1 of 1 Posts
Status
