I want to substitute the two fans of this projector with similar ones more quite, but I don't know the specifications of the ones inside the unit. I also believe that the ones inside need replacement.
Can you Help me? I just need to know the air flow per hour...
The fans are:
Matsushita electric (I think now Panasonic)
Model FBP-08A12L
Can I use less air intake ones in order to reduce the noise?
I am thinking on buying PAPST ones:
PAPST 8412 N/2GL 19,4 CFM, 0.6W, 1500RPM, 12 DBA or
PAPST 8412 N/2GML 26,5 CFM, 0.9W, 2050RPM, 19DBA
Thanks in advance
The fans are:
Model FBP-08A12L
Thanks in advance
