1 - 9 of 9 Posts
Hello everyone.
Currently I am ripping my BRD's to MKV, but I think I would like to rip them to BRD Folder rips going forward.
When I rip to MKV, I use MakeMKV. Select the title, select lossless audio, and off it goes. The ripping time is dependent on the BRD drive, nothing else.
Back in the day, I tried ClowBD, and this seemed to work well enough, though it would have to extract the files, then remerge the files into the final BRD Folder format of my choosing, taking nearly twice the time.
Is there any way to go from disk or MKV to BRD Folders, keeping only the main movie and lossless audio, without this intermediate step?
Premium Member
AnyDVD HD as well. Basically the same as DVD Fab (direct competitor). Also paid, but been around longer and they are good at updates every time new protection comes out.
If you are ripping BD disks you need/have one or the other anyway so might as well use them for this. There are free decrypters but none of them hold a candle to those two paid apps.
Unless AnyDVD has changed in the last year or so, it doesn't hold a candle to DVD Fab (just my opinion).
I have used both and as good (& early) as AnyDVD was, its not a full-featured ripper. It is more of a decrypter and an override/bypass utility for HD material and HDCP connections.
DVD Fab has a full featured ripper with a decrypter. It can rip Full Disc or Main Movie Title in both folder and ISO format. Also it allows you to pick & choose titles in case you want some titles in addition to the main movie title.
Also, it can convert to other formats including portable media formats.
The two programs are only similar to the extent that both can be used for BD ripping; beyond that DVD Fab is at a whole other level compared to AnyDVD. It can do what AnyDVD can, however AnyDVD can't do all that DVD Fab can (something that OP wants).
Discussion Starter · #5 ·
Last I saw, AnyDVD was not able to select the main movie and extract just that, it was only able to take the whole disk. Please correct me if I am wrong..
hd decrypter with DVD Fab is actually free. i think the paid version adds all the other file formats like avi, mkv, and the burning featurs.
DVDfabs website has a section for free software and i downloaded hd decrypter... which is dvd fab 8 i believe and i rip main movie and full disc blu-ray and dvd no problem.
The HD Decrypter from DVD Fab is free however I don't think the BD ripper is free once past the trial period plus the HD Decrypter is not updated as fast as the paid subscriptions. For instance it's going to be about a month before you'll be able to rip The Last Airbender with the free version.
I've been using DVD Fab for at least five, probably close to ten years now and never had an issue with it.
interesting, i wasnt aware of that. Ive had it for some time now and it hasnt ran out of the trial. I havent had any problems ripping movies but i havent tried anything like the last airbender.
1 - 9 of 9 Posts
