  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
Faulty plasma panel? (small video inside)
836 Views 1 Reply 2 Participants Last post by  hammerdwn
Hello,
Samsung PS-42E7S, screen keeps flashing (dark in the mildle) with good sound.
Can this be a problem on the "plasma panel"?
I hear a sound click click click on the "Y Drive" board when the screen is flashing, if i disconnect the Ybuffer from the panel, the sound click maintains and dark screen, then if i disconect the Ybuffer from the Ydrive board the click stops...
Tested the power board and its ok.
Can the problem be on the Y boards or am i wasting time because its a bad "plasma panel"?
Thanks a lot
1 - 2 of 2 Posts
Most likely bad panel.
1 - 2 of 2 Posts
