Status
Not open for further replies.
1 - 8 of 8 Posts
Discussion Starter · #3 ·
I will be setting up theater system and want a way to test the audio and set up the video
Well, testing for what? Are you going to use the results to modify or treat the room? Are you going to EQ it electronically? There are 3 obvious starting points for audio (ETF, TrueRTA and RoomEQWizard) but which you choose will depend on what uses you have.
Kal
Discussion Starter · #5 ·
If I can I would like to use it to modify room treatments, but I am still learning about that myself. I do want to use it for speaker placement (sub) and setting up the EQ. I have been selling theater systems for over 2 years and I would like to be able to give my customers a better theater system set up then I can do with just a test disc. I would like something that would be EZ to use and small'ish to have in my car. I don't want to put the $ in video as much as I want to put it in audio at this time, I think I can set up a the video by eye where it looks "good." The video can come later after I get the audio set up down.
To elaborate on what Kal said, I would start with a PC or laptop, a sound card, ETF software ($150), and a RadioShack SPL meter which doubles as a powered microphone. Add connectors, a stand to mount the mike (SPL meter has a standard camera mount socket so you can use a camera tripod).
Then factor in considerable time to learn how to use it.
1 - 8 of 8 Posts
Status
