  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
few setup questions re denon 3803, replay h2000 and smasung hdsatreceiv ts160
162 Views 0 Replies 1 Participant Last post by  jayjay139
Hi,
Just got my sammy hln507w...WOW. few setup problems with the theater system.
1) my replay hs2000 controlled my old sony b2 sat rec with a serial cord The samsung doesn't have a serial port and all the irblster codes don't work. samsung isn't listed as a maker of sat either. How do i control it?
2) the sammy has 3 component inputs the first being for 480p/i the others for 480p/720p/1080i. The sammy goes via dvi to the highest res on thetv. Fine and there's a switch on the receiver so you have to choose dvi or component (not both?). Anyway i also sent s-vid to the replay, which goes out to the denon avr. The denon is suppose to upgrade the vid signal and i send it out to the tv. But the i can't find what the denon upgrades it to? I would imagine 480i or p and so the first component with lower res would be appropriate. But if its 480p, than I can go to the second and take advance of the sammy to up it to 720p?
Jack
Status
Not open for further replies.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
Status
