1 - 3 of 3 Posts
· Registered
I'm following the stickied guide setting up Windows Media Center.
However, when I go to add external filters, ffdshow is not in the list. If I browse to the ffdshow program file I don't see anything in there that explicitly says ffdshow audio decoder.
Am I doing something wrong? ffdshow is obviously installed, and I did the other setup things in ffdshow outlined in the sticky.
Running windows 7 home premium 64 bit
· Registered
Are you running the 32bit or 64bit version of MPC-HC? Are you running the 32bit or 64bit version of ffdshow?
You need to either have both ffdshow and MPC-HC to be the same bit in order for them to work with each other.
The link the in the Windows Media Setup guide refers you to the 32bit version of ffdshow, just in case that's where you got the program from.
1 - 3 of 3 Posts
