1 - 3 of 3 Posts
Hello,
Today I experienced a very strange issue, while watching the Blu-ray of Pirates of the Caribbean 1. When I was using the uncompressed LPCM track, I did not have any sound from the right surround channel. I narrowed the issue down to the ffdshow audio decoder.
My set-up:
MPC-HC (one of the latest versions) -> MPC internal splitter (LPCM selected) -> ffdshow audio decoder -> Reclock renderer to AC3 -> SPDif out -> receiver
I tried the following permutations to the above:
1) Select the Dolby Digital track -> OK
2) Use the MPC-HC internal LPCM decoder -> OK
3) Do not use Reclock, use ffdshow to encode LPCM to AC3 -> NOK
4) Use Haali splitter -> NOK
So it clearly has to do with the decoding of LPCM by ffdshow. BTW: both ffdshow and reclock report 6 channels being available. For some reason the 6th is just not decoded.
My question: is this a known bug? Is it just this movie (it is the first time I noticed)?
Gerbrand
I too am experiencing this problem. I noticed it after listening to tracks when decoding DTS via my amp, if i bypass ffdshow the rear audio is much more pronounced but I would prefer to use ffdshow for DTS-HD decoding as my amp doesnt support it.
With the volume plugin enabled it shows that audio is registering with BackL and BackR but if I mute BackL no audio can be heard although ffdshow still shows sound on BackL.
MPC-HC (various versions) -> Haali Media Splitter -> ffdshow (various versions)
I have tried various configurations and I cannot get it to seperate BackL BackR
Please someone help!
Discussion Starter · #3 ·
I also have not been able to resolve the issue yet. With one of the other two Pirates of the Caribbean films, I don't get sound from the LEFT surround even though both ffdshow and also my surround receiver indicate the signal is present.
I have not tried decoding DTS-HD yet, but AFAIK ffdshow will only decode the so-called DTS-core.
Is there a ffdshow-audio forum somewhere, so that this issue can be posed to a more specific audience?
Gerbrand
1 - 3 of 3 Posts
