Hi all,
sorry for another ffdshow thread, but i have a few questions i hope some one can help me with
my setup
win XP pro
sonic cineplayer 1.5 filters
zoomplayer 3beta1
I have edited a zoomplayer graph by placing the "(ffdshow ax)" after the filter presume this correct.
I have entered the AllowAllRenderers in the registery
some one posted the following
which i did
I can't seem the find the Nic's postprocessing or default
I can't seem to find the process whole image. check box
I can't seem to find "process whole image" check box
in fact i can't seem to find most of the thing that where mention, am I using the same programe is ther more than one?
also some one said the the mpeg 2 box in the codecs should be ticked, but mine is greyed out, can only select raw.
i selected to show the task bar icon but it does not show,
Is there any way to alter the ffdshow settings while zoomplayer is playing.
looked in the filters in the context menu but there's nothing there.
How do i know that ffdshow is working, the filters registed ok in zoompayer.
Any help would be appreciated
i have tried the search funtion but due to server problems it keep get turned off.
Steve
my setup
win XP pro
zoomplayer 3beta1
here's the settings i think work best for DVDS in ffdshow...(i suggest you get the newest alpha version of ffdshow dated 10-03-02) |
In the post processing section the ONLY thing you want enabled is Nic's postprocessing...i keep it at default...the effect is VERY subtle but i think it brings out a little detail in distances |
In the sharpen section i use unsharp mask at 45 and "process whole image is checked... (i like ALOT of sharpness, but that's just my preference) |
in the blur+nr section i use gradual denoise at 15....it's important NOT to check "process whole image", or you will get subtle distortions in moving stuff... |
Steve
