Your receiver doesn’t pump out enough voltage to the LFE out for the pro amp which wants a stronger signal. You either get something in between the amp and the Denon or you adjust your LFE out to a higher output through your receivers settings.
When I adjusted the settings it needed to be at least +9db on the LFE channel before I could get a strong enough signal to power the amp.
