Status
Not open for further replies.
1 - 2 of 2 Posts
Banned
I'm currently using a Sony W400Q to project a 92" wide 16:9 image onto a white wall. Brightness is good.
Will the Firehawk be a good screen choice?
The main reason for considering a Firehawk is because I will be upgrading projectors withn the next year. But it must work OK for the W400Q for the time being.
I would think that you would be okay since the Firehawk does have a positive gain. I've got a Sharp XV99 that I'll be using in the theater that I'm building until I can upgrade to a better projector and I'm planning to use a Firehawk. It's my hope that although the lumens on my projector are not impressive (400) the screen will improve the contrast enough that I can live with the Sharp for a while longer.
1 - 2 of 2 Posts
Status
