i have a mitsubishi hs-hd2000u dvhs deck and im pretty sure the firewire connections arent working,when i go into the menu it wont search for any firewire connections it just sez searching for nodes?this unit worked good with my mits dlp(wd62825)until recently,and currently the tv is reconizing other firewire devices,so i think the tv connections are ok,even thou this vcr is a dinosaur,i used it very little and it makes great hd recordings ,is it worth fixiing? can firewire connections go bad? any input would be great.....randy
