I have had my Panasonic E85 for about 2 months. Generally, it has worked very well. I like the TV Guide, simple editing, dubbing to DVD-R all have no problems. But I seem to have another new problem every couple days. These problems don't feel like hardware problems but more of a problem with the firmware built into the unit.
Here's some of my problems I have seen:
* We were often getting the message when we turned it on "Error has occurred. Please press enter". The unit then went through a self-test operation and apparently everything was fine. Ultimately, we figured the problem was that the unit was in standby, actively recording a timer program, and someone hit the System-OFF button on the universal remote control. We have a universal remote with a macro button programmed to turn off all components. I have the discrete power-off code programed in the macro for the E85, not the power toggle code. This is not very nice behavior (it should just keep recording), but I think I have my family trained to check the Panny before doing a System-OFF of all components.
* Then a couple days ago, I got the same error message but no one did the System-OFF on the universal remote. The unit was recording a show at 3AM so I know no one disturbed it. In the morning the same error message was on the screen.
* One time, my wife was in the title navigation menu and the unit locked-up. She called me at work in a panic and I couldn't believe it wouldn't respond. When I got home, I found she was right. Nothing worked so I pulled the AC power cord. After a couple minutes it booted up correctly.
* On another occasion the unit would not come out of standby. When you hit the power button, the unit would briefly display something on its front panel and then turn off again. I disconnected the power cord and again that got it working.
Is anyone else having these kinds of problems with the E85? Is there a later version of firmware that I should get installed? If so, how do I tell what version I have? Could this really be a hardware problem instead?
