So I am about to start my first DIY project.
2 14 cuFT sonotube enclosures tuned to about 17hz with an 8 inch port. I will be using one 19Ov.2 in each enclosure. Most likely being powered by an ep2500.
My room is about 18 x 14 with cathedral ceilings about 17' tall at it's highest point. It is completely open to a rather large kitchen with the same ceiling height.
1) What do you guys think is the minimum sonotube diameter that can be used with an 18 inch driver and 8" port?
2) Should I be buying the D2 or D4?
3) How necessary is a subsonic filter? I can purchase the eQ2 from eD for the SSF, but I would much rather get a BFD, which I dont believe has a SSF.
4) I am not sure about placement yet. Maybe both up front, both in the back. one up front one in the back. So I may have phase issues. Can I set the phase for each sub individually with the ep2500?
Thanks for your help guys. I am returning an eD-350 so I will be receiving store credit from eD. So I am kind of limited to their drivers. I was also looking at their 13Av.2 drivers which I was liking because of the smaller footprint enclosures I would be able to build. They cost about $100 more each but I am not sure if they would give me enough output for my room.
This is for 75% HT, 25% music?
