  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
First DIY Screen Build for an Optoma 5500+ UST -
605 Views 3 Replies 2 Participants Last post by  MississippiMan
We have a daylight basement that doubles as both a home theater and kids playroom. We've gone through 2 large LCD's over the past few years due to relatively minor contact from kids being kids (flying legos, etc.). So, instead of investing in yet another LCD, I decided to experiment with a UST. I found a barely used Optoma 5500+ that I plan to protect in a low media console I am building with a slide out top to protect the projector when not in use.
As I turn my attention to the screen, my priorities include:
1. resiliency to flying nerf, lego, and other toys
2. low cost (just in case we fail @ priority 1)
3. good performance despite significant ambient light (all windows are 90deg from screen on right hand side).
4. flatness (testing the projector on the bare drywall showed just how finicky UST's can be with less than perfect surfaces)
5. flexibility (prefer NOT to have to replace all the drywall if this experiment fails).
After spending a bunch of time reading the many helpful threads in this forum, I am leaning toward the following approach but thought I should check the collective braintrust before pulling the trigger:
Questions I have about this approach are:
1. Does TWH need to be glued to the drywall or a frame to prevent noticeable warping after painting? If so, I may lean more toward using Sintra/PVC
2. To please the boss & her chosen decor, I am leaning toward framing the screen with some relatively ornate crown moulding. What are the potential problems with this kind of installation? Also, should I plan to include some black velvet matting within the frame to limit light spill? If so, is there an ideal size black velvet border for a 100" screen?
3. Would it be possible to use a chair rail (which is designed to hold a panel) as an alternative to a french cleat and/or adhesive to mount either TWH or Sintra to the drywall. Perhaps something like this Basswood Chair Rail/Wainscot Cap/Picture Frame Moulding from HD?
Thank you for any guidance or insights the community is willing to provide this complete newbie.
3138152
See less See more
1 - 4 of 4 Posts
Hello!
OK...so if we are talking about a UST and the desire for some ability to resist Ambient Light, we need to approach every aspect of this DIY Screen Build carefully.
Certain aspects will bear little if indeed no compromises.
1st off, I would suggest the use of Sintra over the TWH because of both installation and coating adherence considerations. TWH will easily accept the desired paint, but to make such paint resist scratching by the wee cretin's activities, a pre-priming of the TWH should be strongly considered...using a special Primer designed to adhere to very smooth surfaces. Sintra does not require such,
Also, the TWH would require mounting to a stiff under-laying substrate, on in the least a perimeter frame constructed of a warp resistant hardwood such a Clear White Poplar. Then there is the mounting to consider.
Sintra can be had in a thickness of 1/2" and at that thickness it is extremely stiff and flat, and will hang as straight as the mounting itself will allow it to....forever. It would never warp or bow. Thinner Sintra (6mm) would work great as well but would need some rear support to hang as flat as possible over the Wall (...does the Wall itself have any pronounced waves or dips, or is it just unevenly textured...?)
As for mounting, the use of anything such as a Chair Rail Trim would raise the material off the wall at least 3/4"...and that of course doesn't take into account the thickness of either given screen assembly...unless by virtue of your drawing your thinking of cupping the raw material with the molding...which I do not suggest doing.
Personally speaking, hanging either material upon the wall in the exact position the projected image presents is the only sane way to get started. The you paint it in place. If I had leeway to do things as I would see fit, and IF the Wall itself is or can be made Flat via smoothing of skimming within the given image parameters, that would be by far the best, least expensive, and most durable solution. A very thin frame could be placed around the perimeter of the image to catch any "very small" amount of light spill created by any "very small" degree of trapezoidal effect caused by either the PJ's own placement or any slight pitch in the wall surface.
All in all, this should be carefully planned out since you opted to go UST. That would not have been my suggestion had I been asked prior to the purchase. I understand a "bargain" but too often the compromises and considerations outweigh the advantages of any savings....and in the case of a UST I really don't see much if any such advantage in the savings department....and a whole lot of considerations as far as application /installation.
At least as far as the paint choice part goes, things do get simple and straightforward....but truthfully, we gotta get you past the screen build to even start considering the application of the coating.
The Holiday weekend is upon us, and after today I will be out of pocket via the Forum,(4 AM Thursday departure) so I will PM an alternative contact if you need advice prior to next Tuesday.
See less See more
Thanks @MississippiMan - this is very helpful and I'll followup directly.
I would clarify, however, that my decision to focus on UST's was driven by practical vs. cost calculations.
1. kids have already broken a semi-flush mount ceiling lamp during a party a few years ago, so a ceiling mount projector raised some of the same problems as flat panel (or) I would need to build a protective enclosure
2. It's a very long room, so mounting on an opposite wall isn't an option either.
3. installing a ceiling mount projector to acceptable specifications of The Boss (no visible wires) would require a lot more time & work OR installation pro budget. Either of which would also be disqualifying to The Boss at this time.
In the end, I chose to go the UST route b/c traditional projectors weren't a real option & I only chose this specific UST projector b/c it was a bargain.
Hello!
See less See more
  • Like
Reactions: 1
1 - 4 of 4 Posts
