I'm hoping to get a bit of help with converting a basement into a dedicated cinema room (I'm in the UK by the way). I will be using old hardware for the time being, and will be upgrading this over time, so it's just help on the design, positioning, what to include etc, especially as it's an unusual layout with stairs and doors. I have a completely blank canvas (bare walls & floor, no ceiling fitted, and no power/cabling yet), and the layout is attached, and the ceiling is 2.3m.
What I really need help with is:
Let me know if you have any more questions, and thanks in advance!
- Where best to position the screen, and seating
- Where best to position the speakers
- Will a room this size/shape take 7.1/7.1.# or should I be looking at 5.1.#?
- Any pitfalls to avoid with an installation
- What to include (conduit, socket types etc.)
- Any advice on sound proofing the ceiling
- Any other good advice or tips you might have!
