1 - 5 of 5 Posts
Hey guys, Im thinking about just using the beginners guide to building a htpc sticky from the top of the site to help me build the htpc. Im going to go with what the author has as "his pick of htpc," it is as follows:
CPU: Core i3-550
CPU Cooler: stock cooler
Motherboard: Gigabyte GA-h55m-usb3
Memory: G.Skill F3-12800CL8D-4GBRM Ripjaws x 2GB
Graphics Card: (AMD)Sapphire 100287VGAL(VGA)
HDD: Samsung spinpoint F3 HD103SJ 1TB
PSU: Seasonic S12II-430 Bronze
Case: Antec Fusion Remote Black
and then i guess i will need an optical disc drive to rip blu rays.
My question is does this look good to those of you that have htpcs? I dont want to watch tv on it, just stream music and ripped blurays. This will be able to be networked to a home server with no problem right? I would want to do it as a gigabit network. Thanks for the help!!
Discussion Starter · #4 ·
So by looking at your guide I would be all set doing this right?
CPU: Sandy Bridge i3-2100
Motherboard: GIGABYTE GA-Z68MA-D2H-B3
Memory: G.Skill 2z2GB DDR3 1600 "Ripjaws"
Graphics Card: Sparkle NVidia GT440 1GB DDR5
HDD: Samsung F4 2TB Hard Drive
PSU: Rosewill Green Series 430 Watts
Case: Silverstone GD04B
Optical Drive: Lite-On Bluray/DVD/CD Burner
Aftermarket CPU Fans: Cooler Master GeminiII S
Originally Posted by assassin /forum/post/20887355
Are you talking about my guide? No way do I endorse the older Clarkdale CPUs as "my pick".
A decent CPU but get the Sandy Bridge i3 2100 instead.
He said he was getting a discrete card so the cpu doesn't matter that much.
1 - 5 of 5 Posts
