- dual core atom, if its possible, definitely helps with multitasking and keeping GUI responsive while recording, or other background tasks
- consider whether you'll have the pc out of line-of-sight (inside cabinet, or below eye level) for a remote receiver. Ext. IR receivers have the flexibility of being out while the PC is hidden.
- probably a standard HD until the SSD prices are reasonable and bigger, then upgrade
- I have the MCE remote & keyboard, and programmed all needed keys into my Harmony 880
Here's a thread I started with regards to my latest Media Center pc, ASRock ION 330, should take a look and consider it, approx $400 US:
http://www.avsforum.com/avs-vb/showthread.php?t=1158378
