If LCD is what you're going with I've only heard great things about the 8350... I think you should be on the right track especially if this is your first projector, you could eventually move to DLP later on
Originally Posted by chumpchange21 /forum/post/19458289
If LCD is what you're going with I've only heard great things about the 8350... I think you should be on the right track especially if this is your first projector, you could eventually move to DLP later on![]()
Originally Posted by Ahamay17 /forum/post/19463193
If you need the mounting flexibility of the 8350 then that is likely your best choice as you will not find a DLP close to your price range that will match it in that regard... However if you want it simply for convenience and a DLP can fit your situation, and by your description it appears it can, you owe it to yourself to view them both if possible. If you don't see the RBE, and few do, the DLP's sharpness, especially during fast motion viewing like sports/action scenes can't be matched by any LCD in the same price range... Double your price range and the gap narrows, but the DLP still has the edge due to it's sharpness...
And yes you're on the right track...
Myself, I am partial to Mitsubishi, I've put 4 years, and 8000 hours (2nd lamp) on one that to this day still delivers...
