Okay, with all the vacation and time off I decided to try my hand at my first speaker build. I chose my drivers and components, got them, hooked them up outside of the box, and was absolutely thrilled. Granted, no real bass or anything (4" woofers; small build), but great definition and clarity. Cut the boxes out. slapped them together using some wood glue, flush-mounted the drivers, hooked it up to a receiver, and....was underwhelmed. Somehow, the clear, pleasant sounds had transformed into a muddy, poorly-defined mess. I then decided it had to be the closed enclosures' fault (HiVi M4N drivers are not recommended for closed enclosures, but thought I would try), so I cut out a 1 3/8" hole for a 1" port (to be delivered at a later date) in my 3/4" MDF, thinking that would at least improve things a bit. And it did, I think. But the definition still isn't there like it had been.
So, then I began reading up on forums, etc, trying to find out what I did/am doing wrong, and I have a couple possibilities to ask about. First, I believe what I'm hearing is cabinet resonance. It sounds like the cabinet itself is making noise/sound, though very unattractively. I did not believe I would need internal braces, since the scale of my build is relatively small...was I wrong? I'm also confused about lining the insides with a material of some sort. I currently have some Polyfill which I had been using, but in my recent readings discovered that will actually mess with the tuning frequency of my port.
Speaking of the port, there was music coming out of that as well (due to the "port" not really existing yet; it's only a 3/4" x 1 3/8" deep hole in the MDF wall?), is that normal? Of course you can't tell it's coming from the hole when sitting a few feet away, but the sound is muddy.
Something else I wondered about was the actual installation of the woofer (tweeter is external) itself. I just bought some black screws and put it in. I'm sure there's a more professional way of doing this, but is the method I used possibly a culprit?
And as for the enclosure, again, I used some wood glue/clamps to secure it together. Adequate? Not? I can feel the enclosure vibrating when in use...bad?
Apologies if these are really, really elementary questions but, well, I don't know the answers. I still have loads of MDF, so if I need to re-do the enclosures that shouldn't be a problem (frustrating yes) Thanks
