Looking at making a box out of 3/4" MDF. Planning on making ported sub using Shiva-X driver and 4" port. Front baffle will be 1-1/2" thick. All other sides 3/4" thick. I am looking at this size: 19-7/8" height, 23-1/4" wide and 23-1/4" deep. I can go larger or smaller, but I would like to use this size if it models well because this size will match a sub that I already have. Other sub is in another room, but I would be able to switch them if I wanted if they are the same size. This sub will be used in a 1,200 CF treated room. Sub to be front firing with 4" port on the front baffle. Cabinet will be braced. I plan on using a notched brace across the back running horizontally and one or two braces across in the middle. Now for my questions.
1. Should I place one brace across the middle or should I use two braces?
2. I have read that the 300 watt Bash amp will work well. Should I use that or
would I be better off using 500 watt Bash amp?
3. How long do I make the 4" port for tuning. Sub will be for HT use.
4. How much poly fill do I use, where is it placed and is it secured in any
way?
5. Does this model well?
6. Should I do something different?
Thank you for your help.
way?
