1 - 15 of 15 Posts
Hey everyone. I picked up a used table. Its a Sota Star from mid 90s. I need to get a Phono Stage for it. Any recommendations? I am looking to spend 500 used max on the stage.
I plan on sending the unit into Sota to have it looked over.
Thanks in advance.
Discussion Starter · #2 ·
I am thinking of trying the PS Audio GCPH i have their headphone amp and are happy with it.
The PS Audio is a nice phono pre. What type of cartridge does it have?
Discussion Starter · #4 ·
Shure sme arm.. No cartridge on it ATM thinking grado since I like the pair of headphones from them. I am thinking Sonata1.
you may want to check out the Musical Surroundings - Nova Phonomena. It is a MM/MC Phono stage that is battery operated. The batteries are rechargeable in the unit. I have seen one for $700 used. But, maybe they can be had for $500? This is another unit that I am looking at.
Discussion Starter · #7 ·
thanks for the input. i am going with ps audio gcph to start out. got it brand new with warranty for 699.
you paid too much
WOW...The Parasound Zphono would have cost you only $200 and probably sound just as good.
probably not
One of the only Parasound products that is only Aah.
maybe, maybe not BUT the PSaudio has WAY more flexability
Discussion Starter · #13 ·
I have active speakers so I like the factthat I do not need a preamp with the ps audio. Btw hooked it up this weekend and I love what I hear.
Awesome, I used to own the PS audio and loved it as well--definitely competes with even more expensive units. Also used to own the Zphono; outstanding for less then 2 bills, but indeed the GCPH sounded even better IMHO.
how is the chinese tube gear (yaqin)? they seem to garner good reviews, and at the price, it certainly seems worth a look.
1 - 15 of 15 Posts
