1 - 9 of 9 Posts
I am shopping around for my first projector which, ideally, would be under $600.
My current apartment does not get much light, so I am not particularly concerned about light output.
Right now I cannot decide whether I should get a 720p short throw or a 1080p normal throw (please let me know if my thought process is totally off and I should be thinking about something else instead). The room I will be using is 12' by 14', and since I am not planning to mount the projector on the ceiling (at least for the time being), my expected throw will be somewhere between 7' and 11' (it will be placed on a coffee table next to the couch, meaning that the distance from the couch to the screen will be about 10-11'). I understand that the 3' can make a big difference, but the wall corresponding to the sorter throw (7'-8') is better suited to serve as a screen. I have been looking at:
1)  ViewSonic PJD7820HD
Ouch. Price-wise, most (all?) 1080p seem to be outside of my comfort zone. This is borderline. Both ViewSonics will give me a 70" to 100" picture which sounds good...? I am slightly concerned about it's positioning and how well it will perform in my space.
2)  ViewSonic PJD5533W
The slightly cheaper than ST BenQ 720p ViewSonic. Again, not ST - will this perform fine in my somewhat limited space?
2)  BenQ W770ST
Obviously, I can have a much bigger picture form the same distance. But will the 720p be noticeable if I am sitting 10 feet away from the screen?
I will be projecting exclusively movies (no gaming), and I don't particularly care about 3D.
Comments and/or suggestions much appreciated! Thank you!
For movies and Blu Ray you would be disappointed in any thing but 1080p. Do all you can to save up the extra $200 to $300 for a BenQ 1070 or an Optoma HD131xe if you must buy new. If $600 is strictly your budget than shop for referbs or even the used market.
Discussion Starter · #3 ·
Thank you. Technically speaking, I could spend up to $800, but I am not entirely comfortable with the though because I am not sure how often I will end up using it. I am afraid that I will get excited about it for a few months, get bored and put it on the shelf (which often happens to my possessions). That being said, I am sure that a 720p is more likely to end up in the shelf than an 1080p. From what I understand, the refurbs are superior to used because they are under warranty and the bulb is new?
Originally Posted by femmeapoigne  /t/1520225/first-under-600-projector-advice#post_24421133
The bulbs can either be new or have few enough hours that they can still be considered new.
The warranties on refurbs can be shorter than the new-unit warranty, so it's always safest to call and ask.
femmeapoigne,
A few quick thoughts: 1) If you'd rather not spend more than $600, then don't. You can get a great picture for $600. You will not be disappointed, especially if it's your first projector. 2) This is an enthusiast forum, so they snub anything less than 1080p. I have the 770st and it looks excellent on my 94" screen with me sitting about 10 feet away. However, you can still get 1080p for under/right at $600. Look at amazon warehouse deals for the Optoma 131xe.
Hope this helps.
Originally Posted by DragonSixGolf  /t/1520225/first-under-600-projector-advice#post_24640118
nm. just noticed this was necro. why do you guys do that?
I want to claim that 2months isn't THAT necro'd, and it took me about that long to decide on my first PJ. But the truth is I clicked a "related thread" link and then didn't check the date because I'm dumb.
AKA, my bad.
If you're going to spend $600 on a 720p projector, I think you should save more money and get a refurb 1080p. I bought the Benq 1080ST refurb for $799. Just put $20 away each paycheck and in three months you'll have that extra $200. Just speaking from experience, you don't want buyers remorse at this price range. Get what you want once and be done with it. Just my thoughts.
1 - 9 of 9 Posts
