1 - 10 of 10 Posts
Problem: New Mobos doing the blink thing on sleep is been bugging me big time. I want the old style, like: Bright Blue LED ON, Dim Red LED SLEEP, is that so hard? Apparently it is.
Here a hardware project that solves the problem, it also contains a couple of "easier" solutions should you just want to extinguish all LED when asleep.
StpBlink.pdf
You hard core builders, enjoy!
Nice. Thanks for sharing!
I've been meaning to buy some Light-Dims for a low tech solution, but haven't gotten around to it yet. http://www.lightdims.com
I covered a couple bright LED displays with a small piece of plastic cut from a black lawn/leaf/garbage bag. One time I used 2 layers. The thin film stays in place sometimes by static & sometimes by moisture, whichever works best at the time. Once I needed to use a small piece of tape.
Discussion Starter · #7 ·
Doesn't your BIOS have an option to disable the mainboard's lights? Mine does, so I disabled everything except the power button light.
Some do, some don't.
But this geek don't want a completely "dark" machine, that's reserved for OFF in my book. When sleep I want a ever so growing, barely "alive" red LED. Yep that's the length some people go through to make something work EXACTLY as envisioned :D I feel little bit like Steve Jobs. :p
The power and HDD activity lights on my case are pretty bright, but they're nowhere near as bright as the ones on my UPS. They're so bright I draped a piece of cardboard over the front panel so I don't have to sleep during its simulated blazing light of day. :eek:
My wife's alarm clock has a bright LCD panel. She had it two years before she realized it could be dimmed! You could read by the darn thing.
1 - 10 of 10 Posts
