My Setup:
2 SI HT18 D4 in heavily stuffed sealed boxes, each on inuke3kdsp channel @ 2ohms. ie. 1100w of power RMS to each sub. in the front corners of my space (1/8th space).
Measurements:
I measured three spots in the room, audyssey off, and averaged them. I then eq'ed the average at 1/12th smoothing. I try to avoid filters with a Q above 8 as the room will have infinitely more spots i haven't measured and I don't want to cut out/notch the bass too much. In the screenshot you see thanks to room gain, my si18's are down 3db at 16hz, not too shabby.
So i thought, let's go for more extension.. below that...
Proposed filters:
LS12 at 20hz +15db
PEQ at 20hz -15db Q=5
The rest are specific to my room.
Now onto my questions...
Am i going to blow these subs up doing this???
Should i set a limiter? at what? Hold setting? Release Setting? I do 50/50 music/movies.
I've seen @LTD02 talk about a HS12 with neg gain and then raise the overall gain on the inuke by the same amount. Am i doing the same thing with what i've proposed above? They look different as i play with the eq in REW, so i'm not sure.
Should i set delays that are different per sub? They are on the front wall about 7' apart and equidistant from all boundaries.
here is my REW file, should anyone want to check it out:
https://www.dropbox.com/s/md7ww1sdgchmjcg/3-6-2015.mdat?dl=0
thanks,
Pete
Measurements:
Proposed filters:
LS12 at 20hz +15db
thanks,
Pete
