Hi guys,
Quick background: WHSv1 running for 3-4 years on an ex gaming PC, ~20tb added via ~10 disks. 5x2tb currently sitting in a lian li ex-503 connected via USB3 (pcie card), added into DE as separate drives (port multiplier setting on the ex-503).
The decisions to use both USB3 on WHSv1 and the port multiplier setting rather than building an array and then adding to the pool have both hurt me badly in terms of stability of the ex-503. The old WHS just sucks at USB3 (often drops connection overnight), as well as pounding the disks whenever there is any kind of scanning/balancing etc done.
I've been planning my upgrade for a long time, and am torn between a WHS2011 + flexraid/stablebit server with a new gaming capable htpc, or combining both systems into an all in 1, win7/win8 file server/htpc/gaming pc for the lounge room.
No matter the direction I take, I have some decisions to make about how the external drives in ex-503 enclosures are added.
1. USB3 or eSata
2. Separate disks, or build raid5 blocks in each lian li ex-503, then pool them via flexraid/stable bit
If I set the lian li enclosures to port multiplier mode, I can add the separate disks into flex/stable bit just as I do atm with WHSv1 DE. The question is ... will this hammer the disks? What happens when I have multiple apps doing full data scans (meta browser, plex, media browser, windows indexing, flexraid/stable bit etc.) and all disks are trying to be accessed at once.
It seems to me the best option for performance would be USB3 raid5 blocks, with software pooling?
What are people's thoughts on eSata vs USB (ie. onboard controller vs the lian li one) and seperately adding disks vs software pooling multiple hw raid arrays?
USB really seems the easiest/most plug n play option to me, as long as it's more solid under win7/8/WHS2011.
Anyone done anything similar to this?
1. USB3 or eSata
