I moved into a rental house and am relocating my home theater to the basement. Based on the shape of the room, there is really only one place to put the screen, and that dictates projector location (Mitsubishi HC5000). Of course, this location is in the center of the room.
Ok, so toss up the ceiling mount, and away you go. Unfortuneatly, this won't work do to the nature of the ceiling. So my best option appears to be a pole stand with a shelf. The pole will be immediately behind the couch, so it won't be too bad.
The best option appears to be a Premier Mounts 84" Floor Stand with a shelf .
This appears very stable, and I could easily adjust the projector position. I'll only be in the house a year, so doing a more involved permanent install doesn't make sense.
Does anyone have any ideas for a more economical solution?
Thanks in advance.
Thanks in advance.
