I have had no FM reception using my receivers and small antennas at my home.
I just installed a Terk FM-Pro in the attic and have a direct 75ohm feed to the tuner (Outlaw 950 preamp) in my home theater - works great!
I have a second, independent direct 75ohm feed from the attic to my bedroom and would like to connect this to the receiver in that room. The receiver is on the other side of the room and I already have one long coax running around the wall to feed cable television signals. Do I need to run a second independent coax for the FM antenna feed, or can I combine these signals using some type of Y-connector at the wall outlet and run them both through the single coax, splitting them again at the receiver?
