Status
Not open for further replies.
1 - 1 of 1 Posts
Hi,
I have a Barco 801s connected to my HTPC via a HD15 to 5 BNCs cable.
In my HTPC I use to have a Geforce256 card and I just changed it for a Radeon 7200 64M SDR.
I changed the card in hopes of getting a sharper image, but it didn't make a difference.
The image is very soft and the characters are very hard to read on the screen.
With PowerDVD, movies are really clear. It's the PC mode that soft.
I use 1024x768 @70hz and Powerstrip to reverse polarity.
Should I be using a different cable? Would the HD15 to DB9 make a difference? I need to have a cable that would be about 25' to 30' long. Everything goes through my PC, so I don't need to use Svideo or the other inputs on the projector (unless someone will recommend me to do so!)
Any ideas?
Sylvain Dumas
1 - 1 of 1 Posts
Status
